Why are these distances different if both of the objects are centered...
tyson_thomas
Member Posts: 4 EDU
As you can see in the image below, I have two center aligned figures, one is a box, and another is a set of circles. For some reason, when I check the distance between the corners of the box and the edge of the circle on each side, the lengths are different... why?
Project link: https://cad.onshape.com/documents/375c04469b49c2ed9a8aec61/w/44db2b91496b26338701491c/e/993e0813a0060af4fbb190d6?renderMode=0&uiState=6531aa50f45dd6138c556568
Too many dimensions when some constraints will do nicely as well as what may be an error if the pattern is supposed to be symmetric.
Hello Tyson. The circles in both rows are not equidistant from each other. Is that intended? - Scotty
2 -
As @robert_scott_jr_
Says your circles are not the same distance from the center... Also your sketches are not properly constrained so thing will move around, you need to add relations/dimensions to make sure everything on the sketch is "black" (i.e. fully constrained) to avoid this sort of problem.0 -
While the center point rectangle is not a must. It comes with all the constraints needed with out having apply separately such as symmetry or mirroring or...
Pretty convenient.0 -
Thanks! Would this be a suitable solution? (Its very similar to yours glen_dewsbury)
