Extrude with offset fails after I add an unrelated intersection curve
matti_suuronen
Member Posts: 19 ✭✭
Extrude/remove to a face with offset fails if I have an intersection curve between two planes in the history. Suppressing the intersection curve allows the offset to work. I cannot think how the intersection curve would be connected to the extrude or the part I modify
. Is this as expected?
https://cad.onshape.com/documents/d99e896cbe817a1824f5482d/v/101558a7517ba6521d6fe2de/e/a67a390e4499321114863db4
. Is this as expected?https://cad.onshape.com/documents/d99e896cbe817a1824f5482d/v/101558a7517ba6521d6fe2de/e/a67a390e4499321114863db4
