After importing a file and transferring from millimeters to inches my scale to my project too big.
damon_bawek
Member Posts: 4 ✭
I have tried to change dimensions but cannot. How can I scale down a ratlore that is over 2,000 in and I want it don't only be 5.5 in.?
Hi @damon_bawek,
Something doesn't add up as 5.5in is only approximately 140mm, and even if the conversion is 1mm to 1in, that is only 140 inches.
I have a couple of questions:
What format are you importing?
How are you converting/transferring units?
Can you use the transform tool?
Can you share a link to the file?
STL
I push the inch button
cyber_rat_v1.stl - Copy
