Defining an undefined sketch/logo
maximilian_küster
Member Posts: 12 ✭
Hi all,
I want to emboss my logo onto different projects of mine.
I really struggle to fully constrain it.
Is there any "easy" way to do it?
Is your logo created in OnShape or des it come from elsewhere? If elsewhere you could import your logo and create a sketch on top of it and either keep imprinting enabled or as I prefer go in and select use on all the curves. Alternatively if you haven't created it and want to create it in OnShape you will need to fully define it at least one time. In either of these cases keep it in it's own document and version it. After that you should be able to derive it into any document you like and transform it into position.1
