Cuting parts to the shape of others
mia_klauk
Member Posts: 7 EDU
Hello,
I want to cut the blue part to the shape of the grey bottom part, but the blue part needs to keep its curve on the top, is there any way to do it?
@mia_klauk You could use the side faces of the grey to split the blue two times.
https://cad.onshape.com/documents/9f2e3957f5ead551d9339662/w/228a92a037d00e86ac1e9473/e/c6b7ce6ffbfce3acbcf5bc4a?renderMode=0&uiState=655ca7249b23ba4383708c6eThis works, because the side faces of the blue are vertical. Even if they were not, you could always make a sketch on the bottom of the blue, use or intersect the shape of the grey, and then use that to split the blue.
I've tried that but for some reason it doesn't work. Can someone tell me why?martin_kopplow said:@mia_klauk You could use the side faces of the grey to split the blue two times.
https://cad.onshape.com/documents/dabd339fb766e5735c66258b/w/07c36f89eb24a3a5c83a342b/e/9e9be860576bd6073651bcbc?renderMode=0&uiState=65646375568b2e0cab5b4d00
mia_klauk said:I've tried that but for some reason it doesn't work. Can someone tell me why?
https://cad.onshape.com/documents/dabd339fb766e5735c66258b/w/07c36f89eb24a3a5c83a342b/e/9e9be860576bd6073651bcbc?renderMode=0&uiState=65646375568b2e0cab5b4d00Hi, your doc is read-only, so I can't try it myself. Looking a bit closer, you do have the Skizze 4, which you could use for that, but there is a self-intersection in it, which could lead to trouble with all things boolean. You could try to remove the intersection by editing Skizze 4 first. I see no other reason why it should not work, then.
The best way to create a body like the one you are attempting, is probably by using two intersecting sketches. You could extrude the first one as "New" (Neu) and the second one as "Intersect" (Schnittmenge) and immediately get the result you are probably after. No need for additional actions: The tree is pretty short.
Beste Grüße und viel Spaß!
I've tried everthing and nothing seems to work. Here is the editable link to the project:https://cad.onshape.com/documents/dabd339fb766e5735c66258b/w/07c36f89eb24a3a5c83a342b/e/9e9be860576bd6073651bcbc?renderMode=0&uiState=656da4ec25220b32195a5cfbmartin_kopplow said:mia_klauk said:I've tried that but for some reason it doesn't work. Can someone tell me why?
Beste Grüße und viel Spaß!martin_kopplow said:@mia_klauk You could use the side faces of the grey to split the blue two times.
https://cad.onshape.com/documents/9f2e3957f5ead551d9339662/w/228a92a037d00e86ac1e9473/e/c6b7ce6ffbfce3acbcf5bc4a?renderMode=0&uiState=655ca7249b23ba4383708c6eThis works, because the side faces of the blue are vertical. Even if they were not, you could always make a sketch on the bottom of the blue, use or intersect the shape of the grey, and then use that to split the blue.0 -
I see you cleaned up the sketch for the teardrop-shaped part, there are no more self intersections in it. Good.Now the link: The link is there, but you also need to make the document accessible to us in oder to allow editing or copying it. That can be done in the share dialog. Then, we can try. Now, we can only look:
So, either make it public or share a link with copy/edit rights:
I've tried everthing and nothing seems to work. Here is the editable link to the project:https://cad.onshape.com/documents/dabd339fb766e5735c66258b/w/07c36f89eb24a3a5c83a342b/e/9e9be860576bd6073651bcbc?renderMode=0&uiState=656da4ec25220b32195a5cfbhere is the link:https://cad.onshape.com/documents/dabd339fb766e5735c66258b/w/07c36f89eb24a3a5c83a342b/e/9e9be860576bd6073651bcbc?renderMode=0&uiState=658013bc999be47b55866baa
hopefully it works now
martin_kopplow said:I see you cleaned up the sketch for the teardrop-shaped part, there are no more self intersections in it. Good.Now the link: The link is there, but you also need to make the document accessible to us in oder to allow editing or copying it. That can be done in the share dialog. Then, we can try. Now, we can only look:
Have you tried replace face?
https://cad.onshape.com/documents/07e184531b35cb912bec2315/w/38239a6306693dee3e79e0c2/e/7133755d78dad67bd7fdb6c4
Hi @mia_klauk your most recent link is again not working. You need to link to a public document for this to work. Sorry, but we can't help you like this, for without the file, it is all guess and speculation.
