Can't insert cut list into drawing
Richard_InvRichard_Inv Member Posts: 38 PRO
I've built a configurable model out of frames, driven by configurations and variables. The Part Studio shows the cutlist fine, all the dimensions are correct for any given configuration, along with creating a composite part.
However, when I bring a configuration into a drawing and try to insert a Cut List table, I get "Composite parts are required to insert cut list tables" on the insertion dialogue box
Any ideas?
  • emagdalenaC2iemagdalenaC2i Member, Developers, Channel partner Posts: 863 ✭✭✭✭✭
    Have you created that drawing for the composite part made with the cut list, or is it from an assembly?
    Un saludo,
  • Richard_InvRichard_Inv Member Posts: 38 PRO
    The drawing isn't from an assembly, it's just from a Part Studio set up to be configurable. Created a new drawing, imported the configurable with the configuration settings I wanted, brings in all the parts EXCEPT for the composite part created by the cut list. To bring that in, I have to re enter all the settings and import that composite part separately, which introduces scope for human error as I need to make sure the configuration matches the one I already imported for the part studio.
