How to convert a boolean value to integer
sam_sama
sam_sama Member Posts: 2
I've created a configuration checkbox. I want to use the integer value of this boolean checkbox configuration. Is there any function that will return 1/0 for true/false boolean values?
  • ilya_baran
    ilya_baran Onshape Employees, Developers, HDM Posts: 1,272 image
    The expression
    myBoolean ? 1 : 0
    should work.
  • ilya_baran
    The expression
    myBoolean ? 1 : 0
    should work.
