laser joint only working for even number of shelves
philip_koritsas
Member Posts: 2 ✭
Hi,
I'm new to onshape and have been working on a design of a tab and slot storage rack using the laser joint feature script. When I apply the the script to my rack in automatic mode, it will only work if have an even number of shelves. If I have an odd number of shelves, it throws an error "laser joint did not generate properly". I can get it to generate if I deselect the middle shelf, although obviously this means that tab and slots are not generated for this middle shelf.
V1 (rack with no tab and laser joint applied)
https://cad.onshape.com/documents/5640714c293130846bf42310/v/e88f0143067a26692e4c0898/e/93255e910352bc894aba4ab0?renderMode=0&uiState=658764374a94c31b48ca7d30
V2 (even number of shelves, successful laser joint)
https://cad.onshape.com/documents/5640714c293130846bf42310/v/97458743d6740f640633cdb5/e/93255e910352bc894aba4ab0?renderMode=0&uiState=6587644a4a94c31b48ca7d3f
V3 (odd number of shelves, error)
https://cad.onshape.com/documents/5640714c293130846bf42310/v/3001ed52d8fc2db2f5ccb9d7/e/93255e910352bc894aba4ab0?renderMode=0&uiState=658764584a94c31b48ca7d60
Can anyone help me understand what is going on here?
Thanks!
Thanks!
