Templates
wayne_sauderwayne_sauder Member, csevp Posts: 648 PRO
  One of the competitor's offerings that I use for CAM allows me to take a project that is completely programmed, select all the toolpaths, and turn them into a template. Then any parts that have similar geometry where I want to use similar toolpaths I can just apply that template to it. I still have to go through each toolpath, edit the geometry selections, and fine-tune anything that needs adjusted but it saves a lot of time. Once the template is applied you can also delete unneeded toolpaths and it does not affect the template.
  I would love to see something like this in onshape CAM.
