How to make a flange - I can't select the edge when prompted
haurjie_liang
Member Posts: 6 ✭
As the title says, I can't select the edge I want from the sheet metal I've thickened or extruded (tried both).
Red arrows indicated are the edges I want to make a flange from. What am I missing?
You used ticken, but you must select the Sheetmetal first and create the sheetmetal part
@haurjie_liang
You will need to make a sheet metal part first (I would replace your thicken with a sheet metal model and use thicken in that tool). The flange tool only works on sheet metal parts.0
