How to view and edit dimensions
scott_hemstreet
Member Posts: 4 EDU
Hello, I am new to Onshape and can not figure out how to show dimensions in the sketch view. I can see a dimension when I create something in sketch, but I am unable to modify those dimensions. I assuming I have some view option toggled off, but can not figure it out. I can edit a sketch and physically click and drag an object to change the dimension, but can not see a dimension, click on it, and change it.
Thank you,
Scott
Thank you,
Scott
The confusion might be coming from the fact that dimensions don't exist until you manually create them with the dimension tool.
https://cad.onshape.com/help/Content/sketch-tools-dimension.htm
2
2 -
Thank you Matt0
Wow. Never thought of it that way
