How to fix an error with circular pattern?
I created a vase using circular pattern but and I select the add option, I get an error.
this is the document: https://cad.onshape.com/documents/bd1cb6f4db1d76d32185b9c1/w/efa6b81475c9d8f461883608/e/901b9d40069267c56ed2b5c0
Thank you.
  • martin_kopplow
    martin_kopplow Posts: 1,598 PRO
    Nice vase, but things that shouldn't be, do get tangent on top and bottom face, when applying the boolean. I think that you should overbuild the ornaments a bit, or maybe offset the sweep path ever so slightly, and trim them off after the boolean, to avoid self intersection.
