How to emboss a logo to a non planar object
Eric_92
Eric_92 OS Professional Posts: 22 PRO
Ok this is something there has got to be an easy workflow too but I spent about an hour researching feature scripts and could not find a good match.
Say we have an injection molded part with an irregular surface and we want to lightly emboss a logo to it.
The only way I was able to get this to work was to do a removal extrude at a uniform depth greater than intended. Then after that sketch in a "Fill" profile and extrude within the part to fill back to get the depth of the emboss to be uniform through the curves.
It works but not the cleanest workflow... Thanks!
  • martin_kopplow
    martin_kopplow Member Posts: 1,616 PRO
    You could project the logo sketch onto the surface(s), then split the 3 faces involved along the projcted curves, select only the logo faces, and thicken-remove.
  • MBartlett21
    Use Split Face with the sketch (it projects perpendicular to the sketch), then Thicken those faces into the model.
    IR for AS/NZS 1100
    S1mon Member Posts: 4,534 PRO
    You can also just use Move Face after you split the faces.
  • Eric_92
    Thanks guys but I'm not quite following.
    Tinkered with these suggestions but not figuring it out.
    Here is the sample public document:
    I was able to do this with your sample, but only if I moved the logo slightly so that the corners weren't so close to the joints of the surfaces.
  • Eric_92
    Super helpful thank you! Oddly I still could not get the move face to work even after looking at your copy, but got the same result with a Thicken-removal after the split. Thanks, I don't use those functions much.
