Failed to translate. partId values are not valid
scott_bell273
Member Posts: 4 ✭
Good morning, I've encountered an issue that started yesterday. I have been using onshape for almost a year to create parts and have had zero issues until yesterday. I am receiving this message when I try to export any of my parts: Failed to translate. partId values are not valid. My default file choice is step, but when this occured I tried exporting as stl and 3mf also with the same error message. None of my parts will export at this point whether new or older. I am seeking a solution please advise.
same problem here...0
Iam having the same issue any solutions yet0
My work around is to click on the part in the lower left pane and then right click>export.0
That did the trick thanks0
