How do I make an instruction manual for a fully built robot in onshape?
rishik_kandru
Member Posts: 2 EDU
I want to make this instruction manual from the ground-up, but the robot is already fully assembled in an onshape assembly, and I have to keep copying this assembly and deleting the parts I don't need for a specific drawing, and it is consuming a lot of time.
Try using 'Display States'. You can set different states to hide/show the parts you need.
(It's in the assembly)
You can also use 'Named Positions' if you're assembly has moving parts.
