Cutting out text for a cnc laser
schaeffer_rees
Member Posts: 4 ✭
I have a cnc laser that I'm going to use to cut out a bracket that has text in it. I would like to have certain portions of text, the inside of certain letters like o or g for example, to stay in place. I can't figure out how to draw a tab that the software will recognize as holding those inside parts in place.
This is an active sheetmetal model so you can't use boolean, any thoughts?
This is an active sheetmetal model so you can't use boolean, any thoughts?0
The tab tool will do the trick.
https://cad.onshape.com/documents/321455a71404d59728d39e69/w/de2af822cc20719f0ad9eba7/e/9b46ca0e1487c850770492f5
1
