Thread Creator
Hi!
I am struggeling with Thread Creator. I have made https://cad.onshape.com/documents/0b8fe4abefafe60ccc25a846/w/5479256d8958650bd58840ed/e/c874df332966925e10e7329a and trying to add threads into holes in the rings. When adding threads, it will not generate it in the design. Why does it not work?
When I trying to access:
https://cad.onshape.com/documents/ea09fbea12c3ffe805f29835/w/91386826beffc581760fa5d2/e/15e28462a8a4b8952ddd6203
I am getting "Onshape is not connected. Your document is saved. Refresh the browser to continue working on this document." I have tried the link in "inkognito" window with same results.
When trying https://cad.onshape.com/check only issue is " Your system is running an integrated GPU. If you have a dual-GPU system with a discrete chipset (NVIDIA or AMD) you can get better performance by forcing the browser to use the discrete GPU. See Graphics Performance Recommendations for more information."
Any tips to fix this?
Best regards
Nautic
