Transparant background Onshape drawing
Hi, I was wondering how I could export an On shape drawing as a PNG with a transparent background (so that only the line drawings themselves are there with the white background being transparent). Do I need to export the drawing as something other than a PNG file or are there certain settings that I am missing - Thank you!
    S1mon Member Posts: 4,571 PRO
    Use a PDF and then in another tool you could convert to an image with a transparent background.
  • nick_papageorge_dayjob
    nick_papageorge_dayjob Member, csevp Posts: 1,259 PRO
    I assume you mean the 3d model? If so, do the below. Pick download image instead of print on the next window (not shown). It will be a png with a clear background.
