I have lost an assembly .
mick_fairless
mick_fairless Member Posts: 5 ✭
I have lost an assembly. I can't find it anywhere , it is not in trash but all of the component parts still exist.  I worked on the assembly this morning and closed Onshape and reopened it this afternoon to find the assembly apparently missing.  Am I doing something stupid  and is there a way to retrieve that which I have apparentl lost?
    S1mon Member Posts: 4,644 PRO
    It's pretty hard to actually lose work. You should be able to look at the history and find a place before you deleted a tab or did something which would cause the assembly to go missing.
  • mick_fairless
    Thank you for your reply Simon.  I have found the assembly after much searching.
