can a Scatch or Drawing details, be saved as a DXF. And then be Exported and saved on my HD ?
asi_perach
Member Posts: 3 PRO
I deal with a motor desing application called Siemense-SimeCenter Magnet.
Part of this appliaction is used to create the Rotor and Stator. However it is difficult to make any change to the desigen after it was embedded into the SimeCenter Magnet.
This tool can import and use DXF file from AutoCad or Catia.
can a Scatch or Drawing, created by Onshap, be saved as a DXF.
