Next shell problem
chriss_ko
Member Posts: 13 ✭
Hi *,
Here is the next shell problem. I try to shell this part but I get only a error saying "could not shell part with selection" when I select the 3 faces. It tuns read as soon as I select the first face.
There is the link to the document: https://cad.onshape.com/documents/fa4bce245ef9d6596f869a94/w/29a4953d898cab09679c861a/e/ff96850d6203da8e2617ef5d
Cheers, Chriss
It is getting better, It works as soon as I cut of the ears:
I'm sure that I will find a hacky solution for that.
The surfaces are not good. They have many sharp edges and difficult transitions/intersections. Smooth and gradual surfaces are what the shell command wants. I'd recommend rethinking the way you drew the entire model with that goal in mind.
1 -
Cheers, that makes sense to me. I will add the fillets before the shell than and make it a bit more smooth. Thanks a lot!
