Simple Force Simulation can't run, asking for material
Kenny_Harsono
Member Posts: 2 PRO
I ran into the error "
Required property is missing from material." when running a static force load simulation. I have verified that all parts of the assemblies have materials assigned to them. I am confused, what else it requires before successfully applying force simulation to the assembly. Thank you
It sounds like the material you allocated to a part has properties missing, ie E value and so on. Look into the properties of the material(s) you allocated or assign a different material to see if that solves the problem.
