loft problems
lior_feldman553
Member Posts: 2 ✭
Hi all,
I am trying to learn more about onshape, so I started doing some tutorials. I am currently doing an exercise on 3D curves and I thought I followed it perfectly, but when I try complete my loft, it doesn't work.
the projected curves on the sides work but the guide splines turn red when selected.
the tooltip says "all guides should intersect each profile boundary" although I used pierce constraints and there are no gaps.
If you can share a public document I’m sure we can help. The only immediate question I see is that it looks like you have 7 or more separate selections under your guides but your screenshot shows that you have 4. If that’s the case, and some of the guides need more than one edge to get from one end of the loft to the other, you need to select the two (or more) edges under one sub-collector. You should end up with 4 guides, some of which may have more than one edge.
1
