inability to view STL or STEP files on IMAC
nanda_nathan
Member Posts: 2 ✭
Hello - i am unable to view an STL or a step file on my imac running macOS Catalina Version 10.15.7
The tabs say that the file was successfully imported in both cases and even show the image on the tab below. But it does not show up in the main screen where changes can be made. The main screen merely shows the coordinate planes. Any ideas on how to fix this?
It will show up as a tab in the CAD imports folder first. After some processing time, it should show up as a part studio and possibly an assembly too, depending on the imported files. The upload and import steps are separate. Give it some time and check your notifications in Onshape. It's possible that there is some import error.
