Changing variable value breaks sketches inconsistently
paul_botwid
paul_botwid Member Posts: 6 ✭
Hi,
In modeling a parametric box design, I encountered some weirdness when working with variables to control the boxes dimensions.
Basically, when I change a parameter / variable like the box height, it often breaks one of the sketches.
However, if I go into the affected sketch and do a slight change, like adding 0.1mm to a dimension, the new variable value works.
After this, if I go back and reset the dimension to the original value (then didn't work the first time) - the sketch still works out.
Bit hard to explain but please see the attached video and maybe it's clearer.
https://www.youtube.com/watch?v=LGMTfAJhJDg
Any thoughts as to why this might happen and how to solve it?
Is it just a bug or is there something I can do to prevent it?
Thank you
