How to specify chamfer on drawing?
alex_vestas
Member Posts: 69 ✭✭
I can't specify Chamfer dimension on the Drawing. I tried click and select one of the view, then select "Chamfer dimension" tool, but nothing was added.
Try a view perpendicular to the chamfer.
https://cad.onshape.com/documents/f2a4e2f63511d6fca72c0ecf/w/c8c0043d6e3196c892946e7d/e/95543f9ec98ff0e5eaed0f62
Better option is to change views so one is perpendicular.
its doesn't work this way. There is no special perpendicular view. I just want specify dimension on one of the view, Bottom or Top, or side view (right or left)
glen_dewsbury
These changes confused me. My design only had a chamfer on one side of the part, so I couldn't figure out how you got that viewglen_dewsbury said:Better option is to change views so one is perpendicular.
Is it possible to set the setting so that when creating a drawing from Part studio, the each view is marked? (Top view, Side view, Bottom view)? Also, when creating a drawing, the initial settings of Part studio often do not give the view that is needed. Therefore, when creating a drawing, I have to change some of views to rotate them to the desired position.
Yes it works. Don't know why this didn't work when I first tried it. Perhaps I was trying to drag the chamfer pointer not perpendicular to the chamfer, but parallel.
