How to align views in Drawing?
alex_vestas
alex_vestas Member Posts: 69 ✭✭
When manually adding another view, which wasn't present when creating the drawing, it could be displaced. How to align views horizontally  and vertically?
  • afalzate13
    afalzate13 Member Posts: 54 ✭✭
    You could select two two matching vertices and make the line vertical or horizontal to force shortcut the alignment. But it would probably be best to start from a standard view and project the standard views and do the isometric view at the end instead of the beginning.
