(How to) Find/determine simulation min/max values?
Connor_LeCLaireConnor_LeCLaire Member Posts: 33 ✭✭
Hello,
I cannot seem to find a toggle to highlight or display the minimum FOS (or stress) in the result of a simulation. Currently I have to set the range manually to highlight the areas that have a lower local FOS and scrub my mouse over the area until I find the rough minimum from doing so. This is imprecise and may cause me to miss an actual minimum/maximum, especially if the min/max is located internally.
It would be great to have:
  1. Simulation result min/max values displayed (with toggle to show/hide?).
  2. Simulation min/max locations highlighted/pointed to with a line (with toggle to show/hide)?
  3. The ability to view only the volumes of the model with inside a specific range of values (stress, FOS, etc). This makes the volumes outside of the range transparent.
