Inner tubes with different height
Hi folks, here's my model: https://cad.onshape.com/documents/d608802f49d98357c607366c/w/aeb60e77068dddc6fc00ef2e/e/68720aa17f75e400d3353380
What I'm trying to do is to have this base 4x4 cm, and an outer tube (about 3.8cm diameter) and an inner tube (about 1/4 inch diameter). To my surprise (and my lack of knowledge) the extrude actually created two inner tubes.
The one thing I can't figure out how, is how to set that the outer tube get a different height (currently at 1.75cm extrusion) I need the inner one to be 1.75cm and the outer to be something like 2.75cm
Thank you in advance for all the patience and guidance
