Sheetmetal for Imported Part
RJV
RJV Member Posts: 15 ✭
Hi,
Do we already have a FeatureScript/Technique for applying Sheetmetal/flatpattern on imported 3d part to Onshape?
Thank you.
    S1mon Member Posts: 4,644 PRO
    The standard sheet metal tools should work.
  • David_YL_Nguyen
    David_YL_Nguyen Member, Onshape Employees Posts: 184 image
    @RJV as S1mon said.
    If you use the Sheet Metal Model tool with the "thicken" command on the base face of your feature, activate tangent propagation and set sheet parameters (thickness, bend radius, etc.) you should get a working Sheet metal part in Onshape.
