Fundamentals Course - Step Exercise, Slide 13
colin_chadfield
Posts: 2 ✭
I'm working through the Fundamentals Course and have a problem with Slide 13 of the Step Exercise. I've created "Rib 1" but when I select it to use "Linear Pattern" the whole rim of the Step is selected, which can't be patterned. I've deleted and recreated to Rib a couple of times and it appears to follow the rules up to that point.
How do I select just the Rib and not the whole face?
The pattern will look like it is patterning the whole rim until you select the "Reapply features" checkbox.0
