Any idea when? are these improvements being worked on?
in General
I won't go over old ground on discussing these improvements. I believe all the designers wanting to use Onshape proffesionally and profitably will agree they are needed. I do know Fusion 360 suggested the Sheet metalzone would be in 2016. I also know it is not policy or possible to give dates on improvements, however the first two would be requirements before I entered into a Pro plan.
So what is the current positon on:
1) Sheet metal zone with punch/slot library etc and metal bending etc
2) fabrication tools for showing fabrication, easy options for mitring, gussets etc
3) surfacing , being able to work directly with imported surfaces from step/iges etc
hoping to hear all these are likely in the next 6 months, any update on this please.
