<p>Welcome to the Onshape forum! Ask questions and join in the discussions about everything Onshape.</p></p><strong>First time visiting? Here are some places to start:</strong></p><ol style="list-style:inherit;margin-left:25px;"><li>Looking for a certain topic? Check out the <a href="https://forum.onshape.com/categories">categories filter</a> or use Search (upper right).</li><li>Need support? <a href="https://forum.onshape.com/post/question/community-support">Ask a question</a> to our <a href="https://forum.onshape.com/categories/community-support">Community Support</a> category.</li><li>Please submit support tickets for bugs but you can request improvements in the <a href="https://forum.onshape.com/categories/product-feedback">Product Feedback category</a>.</li><li>Be respectful, on topic and if you see a problem, Flag it.</li></ol><p>If you would like to contact our Community Manager personally, feel free to <a href="https://forum.onshape.com/profile/6/LouGallo">send a private message</a> or <a href="mailto:lgallo@onshape.com">an email</a>.
</p>
</p>
Uneven pipe ending
robert_norberg
Member Posts: 4 ✭
I'm making a bent pipe by sweeping, but the end cut of the pipe does not become 90 deg, instead it becomes uneven like the picture. Why?
Without seeing the document (you could share a public doc), it's hard to fully answer, but it looks like your section that you're sweeping is not perpendicular to the sweep path, and then you thickened it, which creates an edge surface which is normal to the surface.
Yes that was the problem. Now I started the sweep path with a short perpendicular line and that solved it. Thanks!0
