Default Hole Tool parameter
fabian_mühlberger066
Member Posts: 16 PRO
Hi,
in my current project I have lots of parts with holes. Drilled, Tapped Clearence etc.
Is there a way to set default parameters for holes? For example If I want a tapped hole it is usually following the DIN norm, or best practices.
Lets say I want an m4 hole, it should have the defaults
- pitch corse (which is simply standard)
- Thread Class H6
- Tread length = 2xDIA
- Bore Lenght = 2,5xDIA or 3xDIA
In most cases, these settins are simply good enough and I would spare a lot of clicking time if I could set those default params for the hole feature.
2
