Several hole features creating errors with each other
finn_colando
Member Posts: 7 ✭
I am trying to create a box with three layers of sheet metal and need several different hole sizes in various different spots.
Each hole feature I've created works if the others are suppressed, but when I try to roll to the end at least one hole feature always fails.
I have checked that the holes are not in the same location on the same material. Hole size and type does not seem to be a factor.
Any idea what causes holes of different sizes in different spots to not be able to operate simultaneously?
https://cad.onshape.com/documents/a6d53f76b9a7d3d386142987/w/ddb478679e3592b9cb74774d/e/f45290ab526126e78b6c21b9?configuration=List_KPyi1QyBUWJl3s=Copy_of_custom&renderMode=0&uiState=664b67165238d356aae81f01
Not sure you can tap 3 layers of parts (sheet metal or not) at once…
