Patterns within feature scripts
carter_brennan
carter_brennan Member Posts: 2 ✭
I am trying to make a script to make a 1x2 rectangular tube with a hole every 1/2 inch down it. So far I have a 1x2 Tube that has an input for length as well as one hole. I am unsure of how to make the whole repeat like a linear pattern within the feature script. I think I have to use "opPattern", however I am unsure how to use it. Ideally it would use the input for the length of the tube to determine how far the pattern goes.
This is where I am at, I would like the hole to go in a pattern up the tube
This is part of the code that I think I need to repeat/pattern.
