Parts in Part Studio not showing up in Assembly
brandon_nason
Member Posts: 7 ✭✭
Some of the siding pieces on my model are not showing up in my Assembly view. If you look on the left side right almost even with the top of the window, the siding pieces are missing. https://cad.onshape.com/documents/6e8ae4d5888348888a640bb8/w/6e10234a35662886ff648f5a/e/edd8c80a039596f5197a4fc0
Brandon, did you get this fixed? In your Workshop assembly I see nothing obviously out of whack nor do I see any area of the workshop that matches up with the image you posted (window frame or window placement. - Scotty0
Unfortunately no, it's still not showing a bunch of the siding. I've zoomed out and circled all the missing boards you can see. This was also in an incognito window thinking something might be wrong with my session.
I've updated my model to give the siding color so now it is easier to see where the issues are.
After reaching out to OnShape support it appears I've run into a bug.0
