Need help finishing a knob design!
teodor_petrov
teodor_petrov Member Posts: 6 ✭
Hey guys, I’ve been trying to finalize this knob design for a friend and I can’t figure out how to get the curved portions made on both sides of the knob. I’ve attached my progress as well as the actual knob I’m designing off of. I can even share the file name so you guys can check it out? I hope to get some assistance!
  • Ste_Wilson
    Ste_Wilson Member Posts: 667 EDU
    edited May 2024
    Looking at your screenshot (you will get better help if you can make the doc public and share it).
    Start with a cylinder then draw a sketch of the shape you want to remove on a plane that goes through the center. Extrude remove, symmetrical.
    You can then take your other cuts up from the bottom face.
