One hole feature for a clearance and a threaded hole
Henk_de_Vlaam
Henk_de_Vlaam Member, Developers Posts: 269 ✭✭✭
edited June 2024 in Community Support
To attach something together with screws, a screw extends through a clearance hole in the loose part and into the thread in the fixed part. Is it possible to make these two holes with one hole feature instead of two?
  • wayne_sauder
    wayne_sauder Member, csevp Posts: 699 PRO
    @Henk_de_Vlaam
    If you set the hole tool up like this it will assume that is what you wish to do. Unless you check the tap through all box. You can also set the termination to blind if you don’t want the hole through the second part.
  • wayne_sauder
    @Henk_de_Vlaam
  • Henk_de_Vlaam
    @wayne_sauder,
    Thank you for the reply. Now I understand.
