How do I get rid of black lines after importing
Hello,
Does anyone know how to remove these black lines after I have imported this model? I tried editing appearance but they remain.
Thanks,
Kieran
  • glen_dewsbury
    If you just don't want to see them. Use display without edges from the display pull down on the right side of display. They don't go away. As Martin indicates You're looking at a faceted object.
  • martin_kopplow
    edited June 2024
    Easy: Just don't import a tesselated model like STL or OBJ, use STEP or Parasolid instead. These lines are actually edges in a body made up of triangles.
  • glen_dewsbury
  • Kieran_Holmes_Martin
    Kieran_Holmes_Martin Member Posts: 6 ✭
    Thank you, that worked great!
