Can I not convert an imported DXF into a sketch?
don_whitmire968
OS Professional Posts: 21 PRO
Hola! I have been running through OnSHape with great success over the past 2 months. Slight issue and from what I have read I don't seem to be alone. Is there no way to import a DXF with the ultimate hope of generating a fully defined PDF print? Please say it ain't so!!!
There is an option to import a DXF into a sketch.
Upload the .DXF you want to import into your document, open a sketch and choose (import DXF), then select the DXF with the correct units.
Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com1 -
OK, so I have the DXF imported into my docs but when I go through the steps there isnt anything in the DXF file library?!? How do I get the DXF to be visible or available in that import window?0
Just to double/triple check:
1. You've uploaded your DXF into your document
2. Your DXF has the file extension .dxf in it
3. You're in a sketch and started the insert DXF/DWG tool
All of this and you can't see the DXF in the dialog that opens? If you would be willing, could you submit a ticket and share with support. This sounds like something isn't working correctly and someone in support might be able to debug why.
Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com0 -
I have gone back through and looked deeper into this through the tutorials and I am still not understanding how to get the DXF to be visible in the import window.0
We have lift off, all is good now.0
