How to create a 'rabbit' or 'rebate' where two shells fit together?
ben_terry323
Member Posts: 6 ✭
I'm modelling half of a shell that I plan to 3D print twice and then fix together, back-to-back. Where the two halves meet, I want a couple of mm or so of one half to fit inside the other. In other words, I want to create a 'rabbit' or 'rebate' on the outside edge of one shell, and on the inside edge of the other. How do I do this?
One solution would be:
- sketch
- use
- extrude surface
- thicken add
- boolean subtract
https://cad.onshape.com/documents/b9ee996578adf250836cf5a9/w/1eefd1de5a773227019fd320/e/daf16ba92d946e556687eb81
0 - sketch
Thanks, yes I've worked out how to split my part, but not how to create that rebate where the two parts are split - how did you do that?0
- sketch
- use
- extrude surface
- thicken add
- boolean subtract
0 - sketch
Thanks so much - precisely what I was looking for.Matt_Shields said:One solution would be:- sketch
- use
- extrude surface
- thicken add
- boolean subtract
https://cad.onshape.com/documents/b9ee996578adf250836cf5a9/w/1eefd1de5a773227019fd320/e/daf16ba92d946e556687eb810 - sketch
