Is there a way to get a sticker/Decal/Image on a corrugated wall?
Tinus
Member Posts: 6 PRO
I would like to add some stickering to a container wall in Onshape.
I haven't found a way to do it, maybe someone found a workaround?
You can try applying the decal to the flat wall of the container, then use Replace Face to replace the flat surface (with the decal) with your corrugated surface. It should work! Note - you may need to create the corrugated surfaces with a spline or other sketch element that creates a single surface body to use for the Replace Face. The Decal will not span across surface boundaries.
Decals that have been applied to suitable faces (planar, cylindrical, arc) will survive some surprising transformations (Replace face, Move face, splits & offsets etc) and end up on faces that are NOT suitable for Decal application (compound curvature, conical faces, etc).
Good luck!2 -
Thanks for answering Romeo. I saw this option, but the surface is not a single surface. I will look into changing it.0
Just wanted to say that I tried this and it worked great, applying a decal onto a curved surface on a part in an imported STEP file. Thanks, all!
2
