Boundary split command
frank_ring
frank_ring Member Posts: 44 ✭✭
I am looking for a solution so that the split command is not completely cut through.
In the case of this box, it should only be split in the edge area, approx. 5 mm deep (construction line)
without cutting through the internal geometries.
How do you solve the problem?
https://cad.onshape.com/documents/dae6c4588a0284cb02b9a3e4/w/dddaf613dd1868619a821444/e/eac1d4c0edeb859065890ce5
  • robert_scott_jr_
    robert_scott_jr_ Member Posts: 940 ✭✭✭
    Hello. If what you want to do is to create a thin slot, then this is one way to do it. - Scotty
