How to make a hollow shell from a loft.
indra_carllistya_pramadio
Member Posts: 2 ✭
Hey, im trying to make a hollow shell from a loft that have a guding lines. But the shell is only made inside the loft, not a "thorugh all" hollow (there's still a little bit part of the loft on top and bottom of my loft) So how to make a "through all" hollow shell from a loft? Thanks
Hi, you need to select all the faces that you want to remove in the hollow feature.0
