<p>Welcome to the Onshape forum! Ask questions and join in the discussions about everything Onshape.</p></p><strong>First time visiting? Here are some places to start:</strong></p><ol style="list-style:inherit;margin-left:25px;"><li>Looking for a certain topic? Check out the <a href="https://forum.onshape.com/categories">categories filter</a> or use Search (upper right).</li><li>Need support? <a href="https://forum.onshape.com/post/question/community-support">Ask a question</a> to our <a href="https://forum.onshape.com/categories/community-support">Community Support</a> category.</li><li>Please submit support tickets for bugs but you can request improvements in the <a href="https://forum.onshape.com/categories/product-feedback">Product Feedback category</a>.</li><li>Be respectful, on topic and if you see a problem, Flag it.</li></ol><p>If you would like to contact our Community Manager personally, feel free to <a href="https://forum.onshape.com/profile/6/LouGallo">send a private message</a> or <a href="mailto:lgallo@onshape.com">an email</a>.
</p>
Why has my green part some unwanted holes?
co_pa587
co_pa587 Member Posts: 8 ✭
edited August 2024 in Community Support
Dear community,
I am newbie in OnShape (used FreeCad for years) and I am wondering why I have these holes in the green part, even if there are no holes drawn in Sketch5 - and also Sketch5 is drawn on "Face of thicken 1" where also no holes were introduced yet.
Thanks a lot in advance!
Copa
https://cad.onshape.com/documents/ec65397a550767191fda392a/w/953a0af89c940673e3a92627/e/e07b549591709633cfc67992?renderMode=0&uiState=66b24b1ab046fb7c211a952b
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,948 PRO
    Holes that are on the sketch face are imprinted by default, causing them to appear in your extrude. You can open your sketch and disable imprinting if you don't want to reference the face you are sketching on.
  • MichaelPascoe
  • rick_randall
    rick_randall Member Posts: 436 ✭✭✭
    Micheal's idea is a good one but a 2nd approach would be to simply select the two circular areas along with the rectangle that you are extruding (three picks instead of one) if for some reason you don't want to disable imprinting. Having said that, my preference is to run with it turned off.
    S1mon Member Posts: 4,574 PRO
    Looking at your feature tree and the model, I would recommend going through the free training which is available. Normally to create shapes like this, you would use Extrude, not Thicken. Training would also help with the imprinting issue.
    https://learn.onshape.com/
  • co_pa587
    I was sure it would be easy
    Good to know. Thank you Michael for this quick and helpful response!
  • co_pa587
    uh, you are right, I thought I tried this already. But thank you Rick, it works too. Good to know! 👍
