Sketching a circle to be extruded on a curved surface
mario_darceuil
Member Posts: 113 ✭✭
Please illustrate how to sketch a circle on a curved surface that will later be extruded.
If your curved surface is a cylinder, use wrap:
https://cad.onshape.com/help/Content/wrap.htm
Otherwise, you could extrude a sketch as a surface up to the curved surface and then use the split tool. Those tools will get your sketch onto the curved surface. But you can't extrude a 3D entity, so you should use move face or thicken. That will get you this:
Or, if your goal is just to have a cylinder poking out of the curved surface, sketch on another plane and then extrude up to face. That will get you this:
1
