Offset plane and angle
graham_lock
Member Posts: 277 PRO
Hi all,
I'm trying to workout how to create a plane at a given offset and then apply an angle to it.
Is this possible or will I need to setup a sketch on an offset plane and then create another plane at an angle to a sketch line?
Once I know the best approach I'll need to create the same in Featurescript so any advice relating to that would be welcomed.
Thank you.
Thank you.
Thank you for your reply.
Can you provide more detail please?
Thank you - got it!
