Linear pattern
mario_darceuil
mario_darceuil Member Posts: 113 ✭✭
Why when I click on the linear pattern tool, the object to be patterned disappears off the screen? Sometime it works and at other times it never works. What can I possibly be doing wrong? This is such a nuisance.Please help, I've wasted so much time trying to deal with this.
    S1mon Member Posts: 4,646 PRO
    Linear pattern in the sketcher or part/feature patterns? I've never had this problem. Are you working at a very small or large scale? The defaults for pattern step sizes might be an issue.
  • mario_darceuil
    Onshape sketcher. Just patterning a circle of 0,25 inches in diameter,
    Of course I will try again. but it happens where it is not working.
  • michael3424
    michael3424 Member Posts: 786 ✭✭✭✭
    That sounds really strange. Are you using an unsupported browser or is there anything else special about your setup? Maybe raise a support ticket if it is something that you can clearly reproduce.
  • mario_darceuil
    I am using Chrome.
