Change faces of a loft
Fraeco
Fraeco Member Posts: 2 ✭
I just started 3D modelling and I'm messing around with trying to create a specific diamond shape.
Right now I'm going from a 16 point vertices polygon to a 8 point vertices polygon using the loft. It creates the faces I need, but now I would like to alter the shape of these faces but I don't know how to accomplish this or even if I'm using the right tool.
I would like to end up with the following shape as the end result. This would require extra faces on the upper loft I presume. But have no idea how to get there. Any help or direction on how to get this done would be greatly appreciated!
https://cad.onshape.com/documents/c8603a92fe8b2122e5fa21b7/w/bb49da2aed943e138e42aa58/e/ecf1bf219b532034dd940ca5
